I am experiencing a critical issue with my GL-MT6000 (AX6000 Wireless Router) after accidentally overwriting the internal EEPROM/factory partition. Could you please suggest a recovery method or provide a factory restore image for my device?
Problem:
While connected via SSH, I mistakenly ran this command:
text
echo "AU" | dd of=/dev/mmcblk0p2 bs=1
Afterwards, all Wi-Fi radios stopped working. In OpenWrt, I get “eeprom load fail” and “probe failed with error -12”.
Restoring official or beta GL.iNet firmware via U-Boot or the web interface did not resolve the issue; only GL.iNet firmware temporarily restores Wi-Fi using fallback, but OpenWrt 24 does not work.
What I’ve Tried:
Firmware upgrade through U-Boot and web interface
Tried to backup/restore /dev/mmcblk0p2, but no good backup exists
Contacted GL.iNet support via email, but only received generic suggestions to re-install firmware
Request:
Is it possible to provide a matching factory image or EEPROM/calibration file for GL-MT6000 (AX6000)?
Alternatively, please share an official factory restore procedure (U-Boot or Linux dd method)
Ready to provide logs or more information if needed
