I have a gl mudi and I broke the oled screen where can I buy the screen as I seen load but all have a wider ribbon
Thanks
Thanks
You broke the plastic or the actually the OLED under that?
The oled screen under it , I found loads but not correct ribbon cable
Unfortunately they can’t help I guess nothing can be done
