Gl_nas_diskmanager app source code?
Hi, I’m looking for the source code for the gl_nas_diskmanage app. I’d like to add support for BTRFS formatted drives as I seem to be able to get everything working manually except the mounting in that app is likely failing because mount requires -t btrfs. Could you kindly point me to the repository so I make the contribution.
Thank you.
Can you mount the disk manually and the router will recognize and use it?
Yes, after installing btrfs-progs I can mount and interact with the file system perfectly fine, however the gl nas apps show the disk with an ‘err fs’ error when I try to share it via samba. Outside of the Web ui I can setup samba perfectly fine but I would like to make it easier for other users.
OK. I understand. Will ask developers to have a check.
