search of “gl-” packages showing in ‘available’ tab but not on ‘updates’ tab
fyi this is on 4.0.1
Because the version of the package already installed in your firmware is higher than the version in the repository.
System packages for GL.iNet are not normally uploaded to the repository. They should follow the firmware version.
These three packages should have come from a previous upload by mistake. Thank you for your feedback, we will clear it up.
I wasn’t checking version numbers I was just looking at the ability to upgrade. something to keep in mind in the future when working on beta that upgrade doesn’t always mean upgrade. Not an issue here, hope it helps.
