Has anyone tried attaching a USB Hub to a GL-RM1? Thinking of trying to run the ATX Board and a FingerBot from the same unit but it only has one USB Port, I could just try it but I don’t want to buy a FingerBot if I can’t use it so thought I’d ask here.
Yes, you can definitely use a USB hub with the GL-RM1! However, I would strongly recommend using a powered USB hub (one with its own power supply) rather than an unpowered one.
Excellent. I’ll order a FingerBot as well. Thanks
