GL-RM1 doesn't get IPV6 address
All my devices in my LAN get an IPv4 and v6 addresses from the router except the kvm GL-RM1. Only IPv4 is assigned. Is there a specific setting to enable ipv6?
Hi, thanks for the feedback.
Could you please share your current firmware version and your upstream router model? Also, if convenient, could you please export the syslog and share it with me via PM?
Hi Thalia, I assume this is not normal behavior if you need the logs. I thought something needed to be enabled.
I realized it does gets an IPv6, but it is scope link not global. Not a big deal for me, it works well with ipv4. I will come back if IPv6 becomes necessary for me. Thank you!
