GL-RM10 Image Seems to be Yellowish
Is there something I can do to fix the color. The image looks to be yellowish color. Image on left is from KVM within browser and the right is on the same webpage on the browser directly.
bro i think you might have NIGHT LIGHT setting in windows on remote PC
Regarding the issue, please check if your controlled device has Night Light enabled. If Night Light is not enabled, please try switching to a different EDID profile and then unplug and plug the HDMI cable back in.
