Both GL-S1300 (Convexa-S) and GL-B2200 (Velica) seem to have similar Processor, RAM, ROM/Storage and other hardware components. Both devices do not seem to have any external WiFI Antennas (I think). I have few questions:
What’s the difference between GL-S1300 (Convexa-S) and GL-B2200 (Velica) in terms of hardware and software capabilities, apart from extra 5 GHz Radio in GL-B2200?
Is the WiFi range (both 2.4 GHz and 5 GHz) similar for both devices?
Is the extra 5 GHz radio in GL-B2200 (Velica) usable in AP mode or is it dedicated for Mesh purpose alone?
Will GL-B2200 (Velica) ever update to OpenWRT 19.07 (or later) based GL.iNet firmware release? I see there is a beta firmware for GL-S1300.
Does GL-B2200 (Velica) support SQM QoS “CAKE”, including “Link Layer Adaptation”, “Per-Host Isolation” and “ack-filter” settings/parameters as mentioned at [OpenWrt Wiki] SQM Details ?
Also does GL-B2200 support IPv6 (DHCPv6 Client with Prefix Delegation on WAN side, DHCPv6 Server / SLAAC on LAN side)?
@alzhao
Does GL-B2200 (Velica) support PPPoE and IPv6 (DHCPv6 Client with Prefix Delegation on WAN side, DHCPv6 Server / SLAAC on LAN side)?
Also are there any plans to enable SQM QoS “Cake” for GL-B2200 (Velica)?
