From a clean firmware 3.215 install,
I’m enabling IPv6 on both my GL-iNet devices: a GL-AR300M and a GL-SF1200.
To activate IPv6,
- Create an executable file /etc/sysctl.d/99-enable-ipv6.conf with proper parameters
- Make /etc/sysctl.d/99-disable-ipv6.conf non-executable
- Reboot the device
Actually, I do so by copying and pasting the existing file and changing the value from the original:
cp /etc/sysctl.d/99-disable-ipv6.conf /etc/sysctl.d/99-enable-ipv6.conf
chmod -x /etc/sysctl.d/99-enable-ipv6.conf
nano /etc/sysctl.d/99-enable-ipv6.conf
Change the value as below:
net.ipv6.conf.all.disable_ipv6=0
net.ipv6.conf.lo.disable_ipv6=0
net.ipv6.conf.default.disable_ipv6=0
Extract of /etc/config/network for lan and lan6 on GL-SF1200:
config interface 'lan'
option type 'bridge'
option hostname 'GL-SF1200'
option ipaddr '192.168.0.50'
option macaddr 'XX:XX:XX:XX:XX:XX'
option proto 'dhcp'
option igmp_snooping '1'
option multicast_to_unicast '0'
option ifname 'eth0.1 eth0.2'
config interface 'lan6'
option proto 'dhcpv6'
option ifname '@lan'
option reqaddress 'try'
option reqprefix 'no'
IPv6 works fine on my GL-AR300M. However, my GL-SF1200 doesn’t grab any global IPv6 address from the same DHCP server.
Have you got ideas how to dig deeper in this issue?
