GL SFT-1200 Opal Power Cycle Problem
After using a new SFT-1200 for a few days successfully (with latest firmware update), there was a storm and the AC power flickered off and on. Power was off for 1-2 seconds. The SFT-1200 did reboot and did re-connect to host wireless system but without data to any LAN device. Could not ping host from SFT-1200 although IP address was showing in SFT-1200.
Upon further testing I determined if SFT-1200 has power failure of 1-2 seconds, this router will reboot, reconnect to host wireless system, get IP address, but NO DATA will pass between host to SFT-1200
If power is removed from SFT-1200 for a few minutes, such as 5 minutes, SFT-1200 reboots and works well.
Logs sent to GL support email and I hope this can be remedied quickly or I will have to pursue different product.
Confirmed the email and syslog arrived our email, already created the ticket, we are undaring check this issue.
My colleague continues to contact you by email. Thank you.
