[GL-SFT1200] Access repeater DFS settings in web interface
I’ve noticed that the DFS-settings for the repeater uplink is only available in the mobile app.
It is not present on the web interface of the GL-SFT1200.
Is this a know limitation?
Is there anything I can do or is it just not available on the web interface?
Thank you :folded_hands:
Could you clarify what you mean by the Repeater DFS setting? If possible, please provide some screenshots so we can better understand.
Kindly also let us know the current firmware version of the SFT1200, as well as the app version, so we can check further.
Thank you for the reply.
The device and version in question is Opal (GL-SFT1200)(Firmware Version 4.3.25).
The Android apps is on version 2.7.5
Here are some screenshots:
Opal
Mobile app
Showing the option “Allow Repeat DFS Channels”
The “Allow Repeat DFS Channels” option shown in the app is included for compatibility with certain models and older firmware versions, and does not apply to the SFT1200 v4.3.25—so it isn’t displayed in the WebUI.
We’ll discuss with the R&D team to see if the app’s display can be further improved.
In newer firmware versions, if both the device and the configured wireless country code support DFS channels, they will appear directly in the scan results without needing to enable this option.
Beryl 7
Web interface
Berly 7
Mobile app
Thank you for the feedback.
If the “Allow Repeat DFS Channels” option doesn’t apply to the SFT1200 v4.3.25, how come it is shown in the app? Is that just a mistake?
Or does the device and firmware support the option, so you show it in the app, but didn’t go through the effort of also adding in the web ui?
As I could only embed one media at a time, I couldn’t add the other screenshots yet.
Here is another one.
Opal
Web interface
Without the option
Yes, this just is a user interface error in the app.
We have already informed the R&D team, and this issue will be fixed in a future update.
