GL-SFT1200 can't connect to openvpn
I got a brand new GL-SFT1200, I can't connect to NordVPN both with the guided wizard and loading the ovpn file. This is what i get from the log:
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Rule 'process_mark'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Rule 'wan_in_conn_mark'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Rule 'lan_in_conn_mark_restore'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Rule 'out_conn_mark_restore'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Zone 'lan'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Zone 'wan'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Zone 'guest'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Zone 'ovpnclient'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Set tcp_ecn to off
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Set tcp_syncookies to on
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Set tcp_window_scaling to on
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Running script '/etc/firewall.nat6'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Running script '/etc/firewall.swap_wan_in_conn_mark.sh'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Running script '/etc/firewall.vpn_server_policy.sh'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Running script '/var/etc/gls2s.include'
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): ! Skipping due to path error: No such file or directory
Wed Jun 5 21:14:30 2024 daemon.notice netifd: ovpnclient (10686): * Running script '/usr/bin/gl_block.sh'
Wed Jun 5 21:14:31 2024 daemon.notice netifd: ovpnclient (10686): Failed to parse json data: unexpected character
Wed Jun 5 21:14:31 2024 daemon.notice netifd: ovpnclient (10686): uci: Entry not found
Wed Jun 5 21:14:31 2024 daemon.notice netifd: ovpnclient (10686): cat: can't open '/tmp/run/ovpn_resolved_ipaa': No such file or directory
Thank you
Paride
Please check this:
