I’m using a router GL-SFT1200 to connect to several different mobile phones tethering their wan connection over wifi.
The system is set on router mode, and I use the “Repeater” function.
I saved SSID and password for each of the thetering wifi.
If one of these mobile phones wifi networks fall out of range, the router will wait a long time, I believe 10 minutes, before trying to connect to a different saved network.
Is there a way to reduce this wait time, let’s say to 30 seconds after the fist connection is dropped?
Thanks
