HI all. Recently buy an Opal device and trying to configure NordVPN
1.- Opal is Up & Running
2.- If you connect trought Opal, you can browse
3.- If you install NorVPN software in your laptop, it works
4.- Configuring NordVPN in Opal, you can retreive VPN list servers, but never connect.
The error log is: (insteresting the last 3 lines, starting with Auth Authentication, and ending with /tmp/run/ovpn_resolved_ip)
Thu Jul 24 00:13:09 2025 daemon.notice ovpnclient[9058]: Attempting to establish TCP connection with [AF_INET]138.199.47.139:443 [nonblock]
Thu Jul 24 00:13:09 2025 daemon.notice ovpnclient[9058]: TCP connection established with [AF_INET]138.199.47.139:443
Thu Jul 24 00:13:09 2025 daemon.notice ovpnclient[9058]: TCP_CLIENT link local: (not bound)
Thu Jul 24 00:13:09 2025 daemon.notice ovpnclient[9058]: TCP_CLIENT link remote: [AF_INET]138.199.47.139:443
Thu Jul 24 00:13:09 2025 daemon.notice ovpnclient[9058]: TLS: Initial packet from [AF_INET]138.199.47.139:443, sid=893a4d3d dd649957
Thu Jul 24 00:13:10 2025 daemon.notice ovpnclient[9058]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA
Thu Jul 24 00:13:10 2025 daemon.notice ovpnclient[9058]: VERIFY OK: depth=1, O=NordVPN, CN=NordVPN CA10
Thu Jul 24 00:13:10 2025 daemon.notice ovpnclient[9058]: VERIFY KU OK
Thu Jul 24 00:13:10 2025 daemon.notice ovpnclient[9058]: Validating certificate extended key usage
Thu Jul 24 00:13:10 2025 daemon.notice ovpnclient[9058]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Thu Jul 24 00:13:10 2025 daemon.notice ovpnclient[9058]: VERIFY EKU OK
Thu Jul 24 00:13:10 2025 daemon.notice ovpnclient[9058]: VERIFY X509NAME OK: CN=fr768.nordvpn.com
Thu Jul 24 00:13:10 2025 daemon.notice ovpnclient[9058]: VERIFY OK: depth=0, CN=fr768.nordvpn.com
Thu Jul 24 00:13:10 2025 daemon.notice ovpnclient[9058]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Thu Jul 24 00:13:10 2025 daemon.notice ovpnclient[9058]: [fr768.nordvpn.com] Peer Connection Initiated with [AF_INET]138.199.47.139:443
Thu Jul 24 00:13:10 2025 user.notice relay: Reloading relay due to ifup-failed of ovpnclient ()
Thu Jul 24 00:13:11 2025 daemon.notice ovpnclient[9058]: SENT CONTROL [fr768.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Thu Jul 24 00:13:11 2025 daemon.notice ovpnclient[9058]: AUTH: Received control message: AUTH_FAILED
Thu Jul 24 00:13:11 2025 daemon.notice ovpnclient[9058]: SIGTERM[soft,auth-failure] received, process exiting
Thu Jul 24 00:13:11 2025 daemon.notice netifd: ovpnclient (9350): cat: can't open '/tmp/run/ovpn_resolved_ip': No such file or directory
