I have been using/testing the 4.x firmware way since it was in development and this same bug is not fixed.
The problem is that the repeater wifi keeps on disconnecting from my wifi and never connecting again. I will have to login to the router and click on connect repeater manually for it to connect. But after some hours, it disconnects again.
This makes it unusable!
Can somebody please look into this as this has been the case since months!
Update
Here is a relevant long after it stopped connecting to my router:
Thu Nov 9 14:16:50 2023 daemon.notice netifd: Network device 'wlan-sta0' link is down
Thu Nov 9 14:16:50 2023 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Thu Nov 9 14:16:50 2023 daemon.notice wpa_supplicant[23950]: wlan-sta0: CTRL-EVENT-DISCONNECTED bssid=50:0f:f5:8b:36:d9 reason=1 locally_generated=1
Thu Nov 9 14:16:50 2023 daemon.notice wpa_supplicant[23950]: wlan-sta0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Thu Nov 9 14:16:50 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-DISCONNECTED bssid=50:0f:f5:8b:36:d9 reason=1 locally_generated=1
Thu Nov 9 14:16:50 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Thu Nov 9 14:16:50 2023 daemon.notice wpa_supplicant[23950]: wlan-sta0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="maru" auth_failures=1 duration=10 reason=WRONG_KEY
Thu Nov 9 14:16:50 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="maru" auth_failures=1 duration=10 reason=WRONG_KEY
Last error seems WRONG_KEY! whereas i did not change anything neither on opal nor on my router!
If i connect manually again (without entering the key) it works!
