GL-SFT1200 without reconnecting
I have a problem and I ask for a suggestion to resolve the conflict. I’m using the GL-SFT1200 and I use a wired WAN network. I have two active networks, one on the 5G frequency and the other on 2.4G (guest). If I start the router it works normally, but after a reasonable time and when I move away for a while, when I return to the router’s range it keeps rejecting the connection. I can’t get 5G anymore and I rarely get it with 2.4G, after trying both for several minutes. Can anyone help?
Updated firmware.
The first thing I’d check is the congestion in your vicinity.
