gl-tor is just api package to control the Tor process and configuration. Without it Tor still works if you start it manually. But gl-tor is in charge of communicate with the UI and set up the firewall etc.
I do not think there is a way to check on command line what is inside your brain. My question is “When you choose gl-tor package version, how are you deciding this? How old version of Tor are you using usually please?”
