GL-X2000 multi wan cellular
Does anyone know if the multi wan function of teh GL-X2000 can aggregate over 2 cellular connection, from the info it looks like you can use any or all of the different types of connection but it doesn't state that you can use 2 different cellular connections, I can't find anything that says that you can or cannot do this, interested if anyone has tried this.
No, this isn't possible. Only 1 SIM is active at the given time.
However failover is possible.
The X2000 is a single modem device, so only one SIM card is activated.
Currently there is not dual modem GL router, but I think we may release a dual modem (maybe 4G or maybe 5G) router in 2026.
