GL-X3000 bricked
My GL-X3000 has been working fine for months. Today I needed to access the admin panel to make some changes but it would not load from 192.168.8.1.
I went to reset the router by holding the reset button for 10 seconds, the router reset but then when powering back on only the power LED lit up. No SSID's showing up in wifi and when connected via ethernet I was still unable to access admin through 192.168.8.1
I followed the process for a bricked router and updated the firmware to the latest version. I got the "firmware update successful, restarting router" screen but then the router just restarted to the same state, only the power LED on and still can't access admin screen.
Please help!
Please try to debrick using this method: Debrick via Uboot - GL.iNet Router Docs 4
As stated in the post, I already followed the process for a bricked router
Same issue here. Worked fine for months. Now it’s a paperweight.
I’ve done the uboot and now when powered on only the power indicator is on.
I’ve emailed them with no response.
Obviously this is an issue that needs to be resolved
Could you share me with the ticket ID or email address?
You can send it via the Private Message.
I don’t have a ticket number. I used the support tab on your website.
Where is the DM tab?
I'll send you a PM.
Was this resolved. I’m having the same issue.
Please send a email to support@gl-inet.com
The agent shall help with it.
