GL-X3000 CBRS fail
Running latest beta and still not working. We have a Baicells LTE network. Tried a known good sim at multiple sites and in lab. Tried B42,43 and 48. Sim works flawlessly in many devices, except this one. We use a blank APN without fail. Always. Something is wrong with GLi implementation. Other slot works flawlessly with Calyx, Dish and TMO sims. Tried both slots. Signal is clearly there, always, but will not connect.
Looking at this more, the IP shown is the core/management data IP. The eNb’s run in bridge and hand out DHCP address for data/internet. That is not showing. The device need to get to the net to hit the cloud EPC for sim to register. Flawless on every brand of CPE I have ever tried.
Mon Sep 25 16:16:55 2023 daemon.notice netifd: modem_0001_4 (3885): udhcpc: lease of 192.168.101.170 obtained, lease time 7200
Mon Sep 25 16:16:55 2023 daemon.notice netifd: Interface ‘modem_0001_4’ is now up
Mon Sep 25 16:16:55 2023 daemon.info dnsmasq[7068]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Sep 25 16:16:55 2023 daemon.info dnsmasq[7068]: using only locally-known addresses for domain test
Mon Sep 25 16:16:55 2023 daemon.info dnsmasq[7068]: using only locally-known addresses for domain onion
Mon Sep 25 16:16:55 2023 daemon.info dnsmasq[7068]: using only locally-known addresses for domain localhost
Mon Sep 25 16:16:55 2023 daemon.info dnsmasq[7068]: using only locally-known addresses for domain invalid
Mon Sep 25 16:16:55 2023 daemon.info dnsmasq[7068]: using only locally-known addresses for domain bind
Mon Sep 25 16:16:55 2023 daemon.info dnsmasq[7068]: using only locally-known addresses for domain lan
Mon Sep 25 16:16:55 2023 daemon.info dnsmasq[7068]: using nameserver 172.17.1.6#53
Mon Sep 25 16:16:55 2023 daemon.info dnsmasq[7068]: using nameserver 8.8.8.8#53
Mon Sep 25 16:16:55 2023 user.notice mwan3[4710]: Execute ifup event on interface modem_0001_4 (rmnet_mhi0)
Mon Sep 25 16:16:55 2023 user.notice mwan3[4710]: Starting tracker on interface modem_0001_4 (rmnet_mhi0)
Mon Sep 25 16:16:57 2023 user.info mwan3rtmon[11827]: Detect rtchange event.
Mon Sep 25 16:16:58 2023 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:53:463] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:58:720] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:59:734] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:59:734] call_end_reason is 3
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:59:734] call_end_reason_type is 3
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:59:734] call_end_reason_verbose is 2001
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:59:744] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:59:744] call_end_reason is 3
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:59:744] call_end_reason_type is 3
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:59:744] call_end_reason_verbose is 2001
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:16:59:744] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:02:204] requestRegistrationState2 MCC: 314, MNC: 30, PS: Detached, DataCap: UNKNOW
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:09:349] requestRegistrationState2 MCC: 314, MNC: 30, PS: Attached, DataCap: LTE
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:09:359] requestSetupDataCall WdsConnectionIPv4Handle: 0x23a5e410
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:09:370] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:09:370] call_end_reason is 1
Mon Sep 25 16:17:09 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:09:370] call_end_reason_type is 2
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:09:370] call_end_reason_verbose is 210
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:09:370] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:10:382] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:10:382] call_end_reason is 1
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:10:382] call_end_reason_type is 2
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:10:382] call_end_reason_verbose is 210
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:10:382] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:11:799] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:12:814] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:12:814] call_end_reason is 3
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:12:814] call_end_reason_type is 3
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:12:814] call_end_reason_verbose is 2001
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:12:824] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:12:824] call_end_reason is 3
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:12:824] call_end_reason_type is 3
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:12:824] call_end_reason_verbose is 2001
Mon Sep 25 16:17:15 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:12:824] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:15:527] requestRegistrationState2 MCC: 314, MNC: 30, PS: Detached, DataCap: UNKNOW
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:22:347] requestRegistrationState2 MCC: 314, MNC: 30, PS: Attached, DataCap: LTE
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:22:357] requestSetupDataCall WdsConnectionIPv4Handle: 0x23a5e410
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:22:366] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:22:366] call_end_reason is 1
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:22:366] call_end_reason_type is 2
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:22:366] call_end_reason_verbose is 210
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:22:366] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:23:379] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:23:379] call_end_reason is 1
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:23:379] call_end_reason_type is 2
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:23:379] call_end_reason_verbose is 210
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:23:379] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:24:796] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:25:810] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:25:810] call_end_reason is 3
Mon Sep 25 16:17:25 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:25:810] call_end_reason_type is 3
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:25:810] call_end_reason_verbose is 2001
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:25:820] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:25:820] call_end_reason is 3
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:25:820] call_end_reason_type is 3
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:25:820] call_end_reason_verbose is 2001
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:25:820] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:28:799] requestRegistrationState2 MCC: 314, MNC: 30, PS: Detached, DataCap: UNKNOW
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:35:324] requestRegistrationState2 MCC: 314, MNC: 30, PS: Attached, DataCap: LTE
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:35:334] requestSetupDataCall WdsConnectionIPv4Handle: 0x23a5e410
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:35:345] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:35:345] call_end_reason is 1
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:35:345] call_end_reason_type is 2
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:35:345] call_end_reason_verbose is 210
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:35:345] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:36:355] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:36 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:36:355] call_end_reason is 1
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:36:355] call_end_reason_type is 2
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:36:356] call_end_reason_verbose is 210
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:36:356] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:37:833] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:38:847] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:38:847] call_end_reason is 3
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:38:847] call_end_reason_type is 3
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:38:847] call_end_reason_verbose is 2001
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:38:858] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:38:858] call_end_reason is 3
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:38:858] call_end_reason_type is 3
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:38:858] call_end_reason_verbose is 2001
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:38:858] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:41:236] requestRegistrationState2 MCC: 314, MNC: 30, PS: Detached, DataCap: UNKNOW
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:48:422] requestRegistrationState2 MCC: 314, MNC: 30, PS: Attached, DataCap: LTE
Mon Sep 25 16:17:48 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:48:430] requestSetupDataCall WdsConnectionIPv4Handle: 0x23a5e410
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:48:435] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:48:435] call_end_reason is 1
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:48:435] call_end_reason_type is 2
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:48:435] call_end_reason_verbose is 210
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:48:435] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:49:447] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:49:447] call_end_reason is 1
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:49:447] call_end_reason_type is 2
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:49:447] call_end_reason_verbose is 210
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:49:447] try to requestSetupDataCall 60 second later
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:50:871] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:51:885] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:51:885] call_end_reason is 3
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:51:885] call_end_reason_type is 3
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:51:885] call_end_reason_verbose is 2001
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:51:893] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:51:893] call_end_reason is 3
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:51:893] call_end_reason_type is 3
Mon Sep 25 16:17:51 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:51:893] call_end_reason_verbose is 2001
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:51:893] try to requestSetupDataCall 60 second later
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:17:54:619] requestRegistrationState2 MCC: 314, MNC: 30, PS: Detached, DataCap: UNKNOW
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:01:401] requestRegistrationState2 MCC: 314, MNC: 30, PS: Attached, DataCap: LTE
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:01:410] requestSetupDataCall WdsConnectionIPv4Handle: 0x23a5e410
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:01:420] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:01:421] call_end_reason is 1
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:01:421] call_end_reason_type is 2
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:01:421] call_end_reason_verbose is 210
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:01:421] try to requestSetupDataCall 60 second later
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:01:811] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:02:826] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:02:826] call_end_reason is 3
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:02:826] call_end_reason_type is 3
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:02:826] call_end_reason_verbose is 2001
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:02:836] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:02:836] call_end_reason is 3
Mon Sep 25 16:18:02 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:02:836] call_end_reason_type is 3
Mon Sep 25 16:18:06 2023 user.info : luci: accepted login on /admin/network/network for root from 10.20.0.118
Mon Sep 25 16:18:13 2023 user.notice root: modem ip different, now regain ip …
Mon Sep 25 16:18:13 2023 daemon.notice netifd: Interface ‘modem_0001_4’ has lost the connection
Mon Sep 25 16:18:13 2023 daemon.warn dnsmasq[7068]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Mon Sep 25 16:18:13 2023 daemon.notice netifd: Interface ‘modem_0001_4’ is now down
Mon Sep 25 16:18:13 2023 daemon.notice netifd: Interface ‘modem_0001_4’ is disabled
Mon Sep 25 16:18:13 2023 daemon.notice netifd: Interface ‘modem_0001_4’ is enabled
Mon Sep 25 16:18:13 2023 daemon.notice netifd: Interface ‘modem_0001_4’ is setting up now
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001_4 (8493): udhcpc: started, v1.33.2
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001_4 (8493): udhcpc: sending discover
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:02:836] call_end_reason_verbose is 2001
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:02:836] try to requestSetupDataCall 60 second later
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:05:659] requestRegistrationState2 MCC: 314, MNC: 30, PS: Detached, DataCap: UNKNOW
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:12:380] requestRegistrationState2 MCC: 314, MNC: 30, PS: Attached, DataCap: LTE
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:12:390] requestSetupDataCall WdsConnectionIPv4Handle: 0x23a5e410
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:12:400] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:12:400] call_end_reason is 1
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:12:400] call_end_reason_type is 2
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:12:400] call_end_reason_verbose is 210
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:12:400] try to requestSetupDataCall 60 second later
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:12:889] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:13:905] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:13:905] call_end_reason is 3
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:13:905] call_end_reason_type is 3
Mon Sep 25 16:18:13 2023 daemon.notice netifd: modem_0001 (31502): [09-25_16:18:13:905] call_end_reason_verbose is 2001
Mon Sep 25 16:18:14 2023 user.notice mwan3[8472]: Execute ifdown event on interface modem_0001_4 (unknown)
We have tested the fuction use Cradlepoint CBRS base station in US, it works flawlessly, refer to pictuer below. I think there are some compatible problem about our device or RM520 with your base station. Can you refer the attachment document to share your device to my account to via our goodcloud? I’ll do depth remote analysis.If you can, please send your devcie mac address and password to our support email(b2bsupport@gl-inet.com)
Share the device to technical support via Goodcloud.zip (206.0 KB)
Hello, where is the attached document you reference?
Also, if the device does not go online, how will you connect, do I need to also connect to a wired wan connection?
I add the attachment the document at last relpy, you need to use ethernet cable or repeater to connect the internet.
Hello, there is no attachment? I have plugged in wan port to a router, verified it is online. Created Goodcloud US account and enabled in router and added it to US dashboard, however US dashboard never shows it there.
Admin panel cloud log just says “No Log”
Updated to new beta and bam, cloud works. Now what. I need my CBRS sim to work. I have to pull it from my van if it needs a wired connection. It is currently online via T-Mobile sim in slot 1. When will you work on it so I am not without.
Everything is shared with you. Email sent to above address.
Thanks.
It works.
