GL-X3000 Spitz AX Rebooting issue [help]
Did you dial the number before?
It is connected now, but it is like 0.00001mbits so slow. Idk why :confused:
I am trying a rebooting now, let us see.
Works but i noticed something
  • speed is ultra slow before: 100mbits now: 15mbits
  • connection somehow drops...
Is there a reset all and everything thing? Like factory reset.
AT+QPRTPARA=3
This will restore some
There are no other orders
Or you can re-brush the module firmware of R03A03
That is sad, i did already. Has no affect :frowning: i did not know resetting the router was that hard. Should have know before touching.
try this method.......
Ok, but i think the internet speed is back to normal after few reboots. Everything looks good now, thanks man!
i tried following version, am i doing something wrong?
RM520NGLAAR03A03M4G_2023_07_25
After the firmware upgrade problem you were having i had to have a ttl of 64 to get internet usage.
So do auto and let connect. Then do manual setup with ttl 64 and apply
Refer to this for module firmware upgrade
