GL-X3000 Telefonica (O2 Germany) - no SMS over 5G SA
my GL-X3000 cannot send or receive SMS with an O2 / Telefonica Germany SIM while it is on 5G SA.
Device: GL-X3000
Firmware: OpenWrt 21.02-SNAPSHOT
Kernel: 5.4.211
Modem: Quectel RM520N-GL
Modem firmware (ATI):
Quectel
RM520N-GL
Revision: RM520NGLAAR03A03M4G
Provider: O2 / Telefonica Germany
APN: internet
In the GL-X3000 web UI under "Cellular Information" I see:
Mode: NR5G-SA TDD
Band: 78
Mobile data over 5G SA works fine, but SMS does not:
  • SMS sent from the GL-X3000 never arrive on the phone (WebUI shows “UNKNOWN” / “Send failed”).
  • Incoming SMS to the SIM are also not shown on the GL-X3000.
  • Neither sending nor receiving SMS works even after a reboot.
With the same SIM in a normal smartphone, SMS send/receive works without any problems.
I can provide AT command output if needed.
Thanks in advance.
Did you enable 5G Plus in your contract?
O2 is known for not providing all feature on 5G SA - using 5G NSA is the solution then.
See: Bei 5G SA kein SMS Empfang und kein SMS Versand möglich | O₂ Community
