GL-X3000 Telekom Germany
Maybe do a modem firmware upgrade as
It was taking about another carrier but it may work for you.
Hi there,
I just got me a GL-X-3000 too. But only LTE is working.
If I connect to 5G tower I get the error: "SIM card not registered"
On my iPhone everything works fine.
Using LTE+5G NSA
Thanks.
But I get an error when I try to connect to a 5G Tower.
„ Operation timed out. Please check the network environment or reboot the device.“
My settings:
hello
Non-locking tower.....
Thanks a lot for your very fast reply.
I still are then only connected with the GL-X3000 to LTE with a slow data speed.
How can I setup the router so it connects to 5G?
My iPhone 14 is receiving way higher speeds.
Technical Support via GoodCloud.tar (192 KB)
Can I see it remotely?
Yes. You can access the router now.
Is "select all" really the best way to get the fastest and most stable connection? Based on CellMapper, only a few bands provide good coverage in my area. Wouldn't it be better to manually select the bands with the strongest signal instead? Or does the router automatically prioritize the best bands by itself? Additionally, does the router have an intelligent band selection algorithm, or would manually locking certain bands improve performance?
