GL-X3000NR - SIM card not registered
I am having trouble getting this to work. I have a TMO business Home Internet. I recently bought the GL-X3000NR.
I have changed the IMEI Number using AT+EGMR=1,7, "my IMEI" The IMEI number changed okay.
I have changed the APN to fast.t-mobile.com
Pin: Empty
TTL: 65
HL: 65
MTU: Empty
Authentication: none
I inserted the Sim card into the router. But after it boots up, I get The SIM card not registered message.
What else has to be done? Am I missing a step?
Try Autosetup first and then change TTL settings after it connects. You may not even need to change TTL since you already have an unlimited esim with the business plan.
follow the steps below to share your device so you can troubleshoot it remotely
Technical Support via GoodCloud.tar (192 KB)Thanks!
