I have a GL-inet x750 router
I’m using a 4g sim to connect to the internet, cable connected to pc, and no wifi enabled
If I disconnect the ethernet cable the 4g signal light keeps blinking.
Ive read that this could be to do with the Wake on LAN
Is this the reason why it keeps blinking and can anyone tell me how do I disable this?
Thanks
legepe
Normally that means there’s traffic going via 4G.
Thats my understanding limbot… so with the computer either switched off or the ethernet cable disconnected… this light should not be blinking! Can anyone tell me what is the best thing to check/do?
The router itself consume a little data. It detected Internet etc.
