GL-X750 to power a GL-AR300M
Hello All
I’m installing a GL-X750 + GL-AR300M in a camper van.
All items working per my needs indoor with indoor testing.
The GL-AR300M is 5V powered normally via a Micro USB cable and/or adapter
To reduce the number of cables…??
Is it possible to power the GL-AR300M from the USB socket on the side of the GL-X750
I already have a short USB A to Micro USB cable
Many Thanks…
Yes, it works.
X750 USB-A port has 5V/500mA output, and AR300M power consumption is <2W.
But please don’t connect other device via AR300M USB port any more.
O.K… Thanks
What do you means by
“But please don’t connect other device via AR300M USB port any more”
I will take short USB A to Micro USB Cable from GL-X750 to GL-AR300M
There is only “1” Micro USB port on GL-AR300M
Do not plug another device into the large USB-A port on side of the GL-AR300M, which would require/consume additional power.
O.K… Understand now… Thanks… :+1:
