Hello there,
Can’t find the answer anywhere…
Are the two external antenna dual band or mono band?
I need to make my own antenna because the relay antenna is very far away.
Hello there,
The two antennas are for LTE only. Not for WiFi.
I understand.
My question was about this two external LTE antenna. I wanna know the spec for build a proper long range antenna.
If you connect long range antenna you can just focus on the specs of the long range antenna.
Generally it is gain on each band.
The current antennas, one is main and another should be Div.
Ok. I wasn’t shure.
Thanks
