Hello
I would like to update my router to the openwrt 21.02 version … this is because I need the (lua-bit32) which unfortunately does not exist in the openwrt 19.7 version!
Can anyone help me with this?
Thank you
I have tried this, and it works well. The only issues that I have run into are.
- Pulling some kmod packages can’t be done as it’s a nightly build, and the kernels need to match.
- Some of the package locations hosted by gl-inet need to be created.
I would love a non-snapshot/nightly build, as many drivers need to be added to the open-source package list.
I had to revert to the 19.07 build as I wanted to extend root to the SD card and can’t see the SD card on the OpenWRT generic build.
On a side note, the GL-inet interface is much easier to use and manage for most things than luci
I love the work and can’t wait for the stable release>
also happy to do testing if you need
