GL-XE300-097 PULI alwasy plugged in
hallo i just bought a PULI
i would like to use it:
From time to time while on the move
but primary as a backup of my home FTTC connection.
My router supports a double wan.
My fear is to damage the battery by keeping the router always plugged in and recharging constantly…
should i remove the battery?
will the router work in that case?
also i bought a refurbished unit and it takes long time (some minutes) after hitting the power button to start the lan / wifi. Is it normal!
Ty in advance for your support
bump any ideas? pls pls pls
I dont have a PULI or any special knowledge but I noticed this:
“GL-XE300 is equipped with a large-capacity 5000mAh lithium polymer battery … the battery supports continuous charging without damaging the battery life
-PG
WOW Ty very much!
Great find!
now i’m very happy :grinning:
