I’ve just cloned the whole gl-inet/openwrt and switched to openwrt-trunk branch, however, I cannot find XE300 as a subtarget. I just compiled a minimal firmware and softwares.
Please fix this.
Also, the wg-installer
from GitHub - freifunk/openwrt-packages: Freifunk specific global OpenWrt Packages is too old, which could lead to ./scripts/feeds install -a
failed with warning that wg-server-installer
doesn’t have a valid pkg version. Please sync with upstream.
If you need the whole built binaries directory to see the result and files, check https://openwrt.kmahyyg.xyz (NOT accessible from China Mainland.)
