GLAR300M - what happened to VPN LED
In previous firmware versions on the GL-AR300M there used to be an option to light an LED when the VPN was enabled (either in software or using the physical switch). I no longer see this option in the software and the LED doesn’t seem to be working (not lit). Any thoughts in this regard? Thanks in advance.
Think I sort of answered my own question. While the configuration is not visible in the GLI GUI, it is in Luci. I think I got it sorted out. Have attached image of my Luci config. The top LED item (WLAN) was already present (I’m assuming this is the wifi LED. The other two (OpenVPN and LAN) I added for the other two LED’s.
Image added to my original post above
Comments are welcome…
Good. I just get a screenshot but you have solved it.
