jlq
I upgraded my AR750S to 3.201 today.
As expected, luci disappeared and I had to reinstall it.
Problem: although I had a success message when installing, I’m getting an error 500 when trying to access it.
uninstalling/reinstalling (with reboot in between) didn’t solve the issue
Anyone had the same issue ?
alzhao
2
Seems that you had problems in installing luci.
Can you just ssh to the router and do the following:
opkg update
opkg install luci --force-reinstall
jlq
3
Thanks.
I ended up “reverting firmware” , a.k.a. factory settings.
This time, installing Luci worked.
Not sure what happened
