Hi.
In 2.27 there is a new script “Gl-Health”.
Where can I find it / can you explain what ir does?
I ask because it seems to interfere with my custom “VPN_Reconnect” script which pings out to check connectivity every 2 minutes.
Thanks,
Glitch
Hi.
Thanks,
Glitch
In old firmware there is gl_health as well.
It is repeater manager.
If you have repeater enabled but cannot connect, it will try to reconnect or disable repeater.
So if your script has something to do with repeater, you need to disable gl_health.
