Gli Inet GL-AXT1800 wireguard server (ifup of wgserver)
I bought 2 Gli.Inet GL-AXT1800 routers to setup a client-server Wireguard VPN setup. I am having issues setting up and connecting to the Wireguard Server. The logs from the server are the following.
“Sun Apr 2 22:35:57 2023 daemon.notice netifd: Interface ‘wgserver’ is setting up now\nSun Apr 2 22:35:57 2023 kern.info kernel: [ 27.013075] IPv6: ADDRCONF(NETDEV_UP): wgserver: link is not ready\nSun Apr 2 22:35:57 2023 daemon.notice netifd: Interface ‘wgserver’ is now up\nSun Apr 2 22:35:57 2023 daemon.notice netifd: Network device ‘wgserver’ link is up\nSun Apr 2 22:36:03 2023 user.notice firewall: Reloading firewall due to ifup of wgserver (wgserver)\nSun Apr 2 22:41:13 2023 daemon.notice netifd: Network device ‘wgserver’ link is down\nSun Apr 2 22:41:13 2023 daemon.notice netifd: Interface ‘wgserver’ is now down\nSun Apr 2 22:41:20 2023 daemon.notice netifd: Interface ‘wgserver’ is setting up now\nSun Apr 2 22:41:20 2023 daemon.notice netifd: Interface ‘wgserver’ is now up\nSun Apr 2 22:41:20 2023 daemon.notice netifd: Network device ‘wgserver’ link is up\nSun Apr 2 22:41:20 2023 kern.info kernel: [ 320.669653] IPv6: ADDRCONF(NETDEV_UP): wgserver: link is not ready\nSun Apr 2 22:41:21 2023 user.notice firewall: Reloading firewall due to ifup of wgserver (wgserver)\n”
My home network is setup in the following way.
Main Router is connected to the internet. A second router is connected to the main router with LAN ports and has DHCP disabled. It is thus acting as a repeater/extender. The Gli.Inet router is connected to the second router via WiFi. The port forwarding is being done on the second router as I do not have access to the main router (Don’t think this has anything to do with the wireguard server not starting though).
If I connect to the 2nd router or the Gli.Inet router, I can access internet just fine. I installed WireGuard app from the appstore and used the QR code to connect to the Gli.Inet wireguard server and it does not connect.
Can anyone provide some help with this?
Wireguard server is designed to serve wireguard client on server’s WAN side. So you need to set port forward.
Also please check the exported wiregurd.conf the “Endpoint” parameter is WAN side IP address, you may change that if you only test it under the main router LAN.
