GLI Router not connecting to Open VPN or wireguard anymore
Hi Guys,
I am getting the log below when trying to connect to Open VPN or wireguard. Can you please assist?
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230): Warning: fw3_ipt_rule_append(): Can't find match 'connmark'
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):    * Zone 'lan'
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):    * Zone 'wan'
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):    * Zone 'guest'
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):    * Zone 'wgclient'
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):  * Set tcp_ecn to off
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):  * Set tcp_syncookies to on
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):  * Set tcp_window_scaling to on
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):  * Running script '/etc/firewall.nat6'
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):  * Running script '/etc/firewall.swap_wan_in_conn_mark.sh'
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):  * Running script '/var/etc/gls2s.include'
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):    ! Skipping due to path error: No such file or directory
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):  * Running script '/usr/bin/gl_block.sh'
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230):  * Running script '/etc/firewall.vpn_server_policy.sh'
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230): Failed to parse json data: unexpected character
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230): uci: Entry not found
Thu Feb 15 11:39:54 2024 daemon.notice netifd: wgclient (11230): cat: can't open '/tmp/run/wg_resolved_ip': No such file or directory
Thu Feb 15 11:39:54 2024 daemon.notice netifd: Interface 'wgclient' is now down
Thu Feb 15 11:39:54 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Thu Feb 15 11:39:54 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
The log does not show any issue. All messages are just normal log noise.
So you need to dig deeper, I guess.
Thanks for the response, ill dig deeper to see what the issue might be
