I have a GliNet Ax 1800 with Luci and I installed openfortivpn , the connection works until i got my email witht the code for authentication with 2FA which i cannot insert in any place.
Do you know how to connect GliNet Ax 1800 with openfortivpn and 2FA (receiving an email code) ?
Or is it not possible?
Is there any other plugin ? I just downloaded the openfortivpn through the official repo and I know that I cannot update my device because then I loose support with this plugin.
Currently I have fw 4.5.0.
Thanks in advance to share your expierence.
