Repro scenario:
- Connect to the Comet (Firmware V1.3.0 release1) using GLKVM App V1.1.0 Release 1 until you see the screen data
- Open the console and reboot the device using the "reboot" command and close the console window again - or alternatively use the reboot button in the top right
- You get a "connection lost" screen that says "Re-Connecting..."
- However, even a minute after the device is back online and with the main GUI also showing the device again as "Online" it still shows the reconnection screen
I'm not even sure I would need this feature tbh, I'd be totally fine if the message just instructed me to close the window and try again. But since it's there and says it's re-connecting, I thought I'd report that this doesn't work for me.
