GLX-3000 WAN disconnection peiodically + 5G feedback
I bought in June 2025 my spitz AX, working quite well , but i noticed some WAN disconnections.
Just a few informations :
Modem version : RM520NGLAAR03A03M4G (untouched / unflashed so far too scared )
mobile French operator : SFR/reglomobile (mvno) 5G NSA
ROM: 4.7.4 release 5 from march 2005
Options in use : adguard tailscale openvpn which is a great setup,
experiences:
  • 5G nsa is stable the whole day but I noticed it switches to 4G (over night randomly between 3 or 4 am and switch back itself to 5G around 8am, sometimes later, I dont know why. It would be better if it could stay in 5G during the night as well (I often check in admin pannel)
  • In october I upgraded to the new rom 4.8.2 when notified : I tried that rom but it was a total disaster . The modem was sometimes in 5G and randomly 4G all the time . Very unstable. It seems that 5G nsa was not managed well or something as changed for band managment in this version as NSA was no longer displayed in the admin pannel
  • I decided to switch back to version 4.7.4. 5G is stable again and displaying NSA again in admin pannel. I had some issue and flashed once using uboot method (10s reset button) reset ans flash it again from admin pannel after boot and resetting again.
  • The routeur is now stable enough in 5G nsa (still expereincing the 4G switch between 3 -4am and switch back itself to 5G around 8am)
  • BUT every 24H (not during day) precisely around 8h54pm the WAN connection drops/disconnect . In the admin pannel I can see that 5G NSA is still active and up but it says internet connection cannot be accessed. I have to manually to click on manual or auto setup to restore the connection, but it should be automatic as it is a saved parameter.
I tried do disable “ Enable Interface Status Track” today in Cellular Status Track (multiwan) and network acceleration to see if WAN disconnect. I didn’t try BAND MASKING yet in cellular settings
I would like to have my WAN connection stable again and Forcing 5G all the time.
Here are the system log (i forgot kernel logs) :
AI says: WAN disconnection you experinces on GL-X3000 isn’t a 5G radio drop , but a software reinitialisation of the network interface “rmnet_mhi0” linked to internal 5G modem .
AI interpretation :
  • Initial network error:
ovpnclient[4677]: write UDP: Network unreachable (code=101)
This indicates that the network stack no longer had a default route.
The VPN and AdGuardHome simultaneously lost their UDP, DNS, and TLS connections—typical of a WAN interface down.
  • Modem interface restart:
net rmnet_mhi0: link_state 0x0 -> 0x1
→ This signals that the RM500Q (or RM520N) modem driver is re-establishing the link. Before that, it had fallen from 0x1 -> 0x0 (not visible here, but implicit).
  • DHCP restart:
udhcpc: sending discover then lease of 100.102.137.105 obtained
→ The modem has been assigned a new IP address. This confirms that the MBIM data session was interrupted and that an LTE/5G reconnection was required.
  • Firewall and Tailscale:
firewall: Reloading firewall due to ifup of modem_0001_4
→ The OpenWRT system has redetected a new WAN ifup, meaning a physical or logical interface outage.
tailscaled[...] monitor: [unexpected] network state changed, but stringification didn't
→ Tailscale observed the temporary disappearance of the default route (defaultRoute=empty).
Probable Cause:
This behavior clearly corresponds to a brief reset of the RMNET link (rmnet_mhi0), often triggered:
by an IP reconnection from the 5G carrier network or an unsuccessful DHCP renewal ();
or by a brief MBIM deactivation due either to the RM520N-GL modem firmware or the PCIe MHI driver in OpenWRT ();
sometimes related to power management or a 5G > 4G antenna switch.
SYSTEM LOGS:
24 20:54:06 2025 daemon.err ovpnclient[4677]: write UDP: Network unreachable (code=101)
Fri Oct 24 20:54:06 2025 daemon.err ovpnclient[4677]: write UDP: Network unreachable (code=101)
Fri Oct 24 20:54:06 2025 daemon.err tailscaled[966]: 2025/10/24 20:54:06 flushing log.
Fri Oct 24 20:54:06 2025 daemon.err tailscaled[966]: 2025/10/24 20:54:06 logger closing down
Fri Oct 24 20:54:06 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:06.858552 [error] dnsproxy: 1.0.0.1:53: response received over udp: "exchanging with 1.0.0.1:53 over udp: read udp 10.100.0.2:46810->1.0.0.1:53: i/o timeout"
Fri Oct 24 20:54:06 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:06.858676 [error] dnsproxy: upstream 1.0.0.1:53 failed to exchange ;tracker.opentrackr.org. IN AAAA in 20.001751995s: exchanging with 1.0.0.1:53 over udp: read udp 10.100.0.2:46810->1.0.0.1:53: i/o timeout
Fri Oct 24 20:54:06 2025 kern.info kernel: [86241.511092] net rmnet_mhi0: link_state 0x0 -> 0x1
Fri Oct 24 20:54:06 2025 kern.info kernel: [86241.515902] IPv6: ADDRCONF(NETDEV_CHANGE): rmnet_mhi0: link becomes ready
Fri Oct 24 20:54:06 2025 daemon.notice netifd: Network device 'rmnet_mhi0' link is up
Fri Oct 24 20:54:06 2025 daemon.notice netifd: Network alias 'rmnet_mhi0' link is up
Fri Oct 24 20:54:06 2025 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity
Fri Oct 24 20:54:06 2025 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Fri Oct 24 20:54:06 2025 daemon.err tailscaled[966]: 2025/10/24 20:54:06 monitor: [unexpected] network state changed, but stringification didn't: interfaces.State{defaultRoute= ifs={br-lan:[192.168.7.1/24] ovpnclient:[10.100.0.2/16]} v4=true v6=false}
Fri Oct 24 20:54:06 2025 daemon.err tailscaled[966]: 2025/10/24 20:54:06 monitor: [unexpected] old: {"InterfaceIPs":{"apcli0":null,"apclix0":null,"br-lan":["192.168.7.1/24"],"eth0":null,"eth1":null,"lo":["127.0.0.1/8","::1/128"],"ovpnclient":["10.100.0.2/16"],"ra0":null,"ra1":null,"rax0":null,"rax1":null,"rmnet_mhi0":null},"Interface":{"apcli0":{"Index":10,"MTU":1500,"Name":"apcli0","HardwareAddr":"koPErlA/","Flags":19,"AltAddrs":null,"Desc":""},"apclix0":{"Index":11,"MTU":1500,"Name":"apclix0","HardwareAddr":"noPErlA/","Flags":19,"AltAddrs":null,"Desc":""},"br-lan":{"Index":6,"MTU":1500,"Name":"br-lan","HardwareAddr":"lIPErlA+","Flags":51,"AltAddrs":null,"Desc":""},"eth0":{"Index":2,"MTU":1500,"Name":"eth0","HardwareAddr":"lIPErlA9","Flags":51,"AltAddrs":null,"Desc":""},"eth1":{"Index":3,"MTU":1500,"Name":"eth1","HardwareAddr":"lIPErlA+","Flags":51,"AltAddrs":null,"Desc":""},"lo":{"Index":1,"MTU":65536,"Name":"lo","HardwareAddr":null,"Flags":37,"AltAddrs":null,"Desc":""},"ovpnclient":{"Index":14,"MTU":1500,"Name":"ovpnclie
Fri Oct 24 20:54:06 2025 daemon.err tailscaled[966]: 2025/10/24 20:54:06 monitor: [unexpected] new: {"InterfaceIPs":{"apcli0":null,"apclix0":null,"br-lan":["192.168.7.1/24"],"eth0":null,"eth1":null,"lo":["127.0.0.1/8","::1/128"],"ovpnclient":["10.100.0.2/16"],"ra0":null,"ra1":null,"rax0":null,"rax1":null,"rmnet_mhi0":["fe80::c9:b533:4667:526d/64"]},"Interface":{"apcli0":{"Index":10,"MTU":1500,"Name":"apcli0","HardwareAddr":"koPErlA/","Flags":19,"AltAddrs":null,"Desc":""},"apclix0":{"Index":11,"MTU":1500,"Name":"apclix0","HardwareAddr":"noPErlA/","Flags":19,"AltAddrs":null,"Desc":""},"br-lan":{"Index":6,"MTU":1500,"Name":"br-lan","HardwareAddr":"lIPErlA+","Flags":51,"AltAddrs":null,"Desc":""},"eth0":{"Index":2,"MTU":1500,"Name":"eth0","HardwareAddr":"lIPErlA9","Flags":51,"AltAddrs":null,"Desc":""},"eth1":{"Index":3,"MTU":1500,"Name":"eth1","HardwareAddr":"lIPErlA+","Flags":51,"AltAddrs":null,"Desc":""},"lo":{"Index":1,"MTU":65536,"Name":"lo","HardwareAddr":null,"Flags":37,"AltAddrs":null,"Desc":""},"ovpnclient":{"Index":14,"
Fri Oct 24 20:54:06 2025 daemon.notice netifd: modem_0001_4 (3069): udhcpc: started, v1.33.2
Fri Oct 24 20:54:07 2025 daemon.err ovpnclient[4677]: write UDP: Network unreachable (code=101)
Fri Oct 24 20:54:07 2025 daemon.notice netifd: modem_0001_4 (3069): udhcpc: sending discover
Fri Oct 24 20:54:07 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:07.070578 [error] dnsproxy: 194.0.5.64:53: response received over udp: "exchanging with 194.0.5.64:53 over udp: read udp 10.100.0.2:46565->194.0.5.64:53: i/o timeout"
Fri Oct 24 20:54:07 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:07.070735 [error] dnsproxy: upstream 194.0.5.64:53 failed to exchange ;connectivitycheck.gstatic.com. IN A in 20.001399597s: exchanging with 194.0.5.64:53 over udp: read udp 10.100.0.2:46565->194.0.5.64:53: i/o timeout
Fri Oct 24 20:54:07 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:07.070578 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:48436->1.1.1.1:53: i/o timeout"
Fri Oct 24 20:54:07 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:07.071063 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;connectivitycheck.gstatic.com. IN A in 20.001197698s: exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:48436->1.1.1.1:53: i/o timeout
Fri Oct 24 20:54:07 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:07.075755 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:34948->1.1.1.1:53: i/o timeout"
Fri Oct 24 20:54:07 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:07.075854 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;connectivitycheck.gstatic.com. IN A in 20.00146846s: exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:34948->1.1.1.1:53: i/o timeout
Fri Oct 24 20:54:07 2025 daemon.notice netifd: modem_0001_4 (3069): udhcpc: sending select for 100.102.137.105
Fri Oct 24 20:54:07 2025 daemon.notice netifd: modem_0001_4 (3069): udhcpc: lease of 100.102.137.105 obtained, lease time 7200
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[966]: 2025/10/24 20:54:07 monitor: RTM_NEWROUTE: src=100.102.137.105/0, dst=, gw=100.102.137.106, outif=5, table=254
Fri Oct 24 20:54:07 2025 daemon.notice netifd: Interface 'modem_0001_4' is now up
Fri Oct 24 20:54:07 2025 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[966]: 2025/10/24 20:54:07 logtail: upload: log upload of 2250 bytes compressed failed: Post "https://log.tailscale.com/c/tailnode.log.tailscale.io/502e815ccbb8438a7b18d20f569194bb42091be584e6bd83aeeb985d8c01ba52": context canceled
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 RAW-STDERR: ***
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 RAW-STDERR: *** Lines prefixed with RAW-STDERR below bypassed logtail and probably come from a previous run of the program
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 RAW-STDERR: [{"logtail":{"client_time":"2025-10-24T18:54:06.611886992Z","proc_id":2297843637,"proc_seq":5},"text":"dns: [rc=unknown ret=direct]\n"}
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: ,{"logtail":{"client_time":"2025-10-24T18:54:06.611968936Z","proc_id":2297843637,"proc_seq":6},"text":"dns: using \"direct\" mode\n"}
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: ,{"logtail":{"client_time":"2025-10-24T18:54:06.61204911Z","proc_id":2297843637,"proc_seq":7},"text":"dns: using *dns.directManager\n"}
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: ,{"logtail":{"client_time":"2025-10-24T18:54:06.616758167Z","proc_id":2297843637,"proc_seq":8},"text":"dns: inotify: NewDirWatcher: context canceled\n"}
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: ,{"logtail":{"client_time":"2025-10-24T18:54:06.75448512Z","proc_id":2297843637,"proc_seq":9},"text":"cleanup: list tables: netlink receive: invalid argument\n"}
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: ,{"logtail":{"client_time":"2025-10-24T18:54:06.754578374Z","proc_id":2297843637,"proc_seq":10},"text":"flushing log.\n"}
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: ,{"logtail":{"client_time":"2025-10-24T18:54:06.75463108Z","proc_id":2297843637,"proc_seq":11},"text":"logger closing down\n"}
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 logtail started
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 Program starting: v1.88.4-tc18ddfa3d-g1ae3b1c43, Go 1.25.1: string{"/usr/sbin/tailscaled", "--port", "41641", "--state", "/etc/tailscale/tailscaled.state"}
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 LogID: 5245be615797118293507c6ef499e924fc8c8c1f9f024da489b5b8ef5cbb170b
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 logpolicy: using system state directory "/var/lib/tailscale"
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 dns: [rc=unknown ret=direct]
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 dns: using "direct" mode
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 dns: using *dns.directManager
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 dns: inotify: NewDirWatcher: context canceled
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 cleanup: list tables: netlink receive: invalid argument
Fri Oct 24 20:54:07 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:07 wgengine.NewUserspaceEngine(tun "tailscale0") ...
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 setting link attributes: netlink receive: no such file or directory
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 dns: [rc=unknown ret=direct]
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 dns: using "direct" mode
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 dns: using *dns.directManager
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 link state: interfaces.State{defaultRoute=rmnet_mhi0 ifs={br-lan:[192.168.7.1/24] ovpnclient:[10.100.0.2/16] rmnet_mhi0:[100.102.137.105/30 llu6]} v4=true v6=false}
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 onPortUpdate(port=41641, network=udp6)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 router: detect nftables rule: firewall mode "nftables" not supported: create nat table: get table: get tables: netlink receive: invalid argument
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 router: nftables rule count: 0, iptables rule count: 207
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 router: iptables is currently in use
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 router: disabling tunneled IPv6 due to system IPv6 config: disable_ipv6 is set
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 onPortUpdate(port=41641, network=udp4)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 magicsock: disco key = d:f597d28cf38ebf49
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 Creating WireGuard device...
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 Bringing WireGuard device up...
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 Bringing router up...
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 external route: up
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 Clearing router settings...
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 Starting network monitor...
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 Engine created.
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 pm: using backend prefs for "profile-4b31": Prefs{ra=true dns=false want=true routes=[192.168.7.0/24] snat=true statefulFiltering=false nf=on update=on Persist{o=, n=[d4EVA] u="remy38000@gmail.com"}}
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 TPM: error opening: stat /dev/tpm0: no such file or directory
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 envknob: TS_DEBUG_FIREWALL_MODE="auto"
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 logpolicy: using system state directory "/var/lib/tailscale"
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 got LocalBackend in 121ms
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 ipnext: active extensions: taildrop, relayserver
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 Backend: logs: be:5245be615797118293507c6ef499e924fc8c8c1f9f024da489b5b8ef5cbb170b fe:
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: client.Login(0)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 offline auto-update: starting update checks
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: doLogin(regen=false, hasUrl=false)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 health(warnable=warming-up): error: Tailscale is starting. Please wait.
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: client.Shutdown ...
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: mapRoutine: exiting
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: authRoutine: exiting
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 health(warnable=login-state): error: You are logged out. The last login error was: fetch control key: Get "https://controlplane.tailscale.com/key?v=125": context canceled
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: updateRoutine: exiting
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: Client.Shutdown done.
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: control server key from https://controlplane.tailscale.com: ts2021=[fSeS+], legacy=[nlFWp]
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: RegisterReq: onode= node=[d4EVA] fup=false nks=false
Fri Oct 24 20:54:08 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:08.636760 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:38553->1.1.1.1:53: i/o timeout"
Fri Oct 24 20:54:08 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:08.636904 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;ccp-lh.googleusercontent.com. IN A in 20.002194338s: exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:38553->1.1.1.1:53: i/o timeout
Fri Oct 24 20:54:08 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:08.643521 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:55559->1.1.1.1:53: i/o timeout"
Fri Oct 24 20:54:08 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:08.643624 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;ccp-lh.googleusercontent.com. IN A in 20.001332194s: exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:55559->1.1.1.1:53: i/o timeout
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: RegisterReq: got response; nodeKeyExpired=false, machineAuthorized=true; authURL=false
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 health(warnable=login-state): ok
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 health(warnable=not-in-map-poll): ok
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: netmap: got new dial plan from control
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 using tailnet default auto-update setting: true
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 EditPrefs: MaskedPrefs{AutoUpdate={Apply=true}}
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 active login: remy38000@gmail.com
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 Switching ipn state NoState -> Starting (WantRunning=true, nm=true)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 magicsock: SetPrivateKey called (init)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 wgengine: Reconfig: configuring userspace WireGuard config (with 2/13 peers)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 wgengine: Reconfig: configuring router
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 monitor: RTM_NEWROUTE: src=, dst=192.168.1.0/24, gw=, outif=19, table=52
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 monitor: RTM_NEWROUTE: src=, dst=192.168.8.0/24, gw=, outif=19, table=52
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 monitor: RTM_NEWROUTE: src=, dst=192.168.9.0/24, gw=, outif=19, table=52
Fri Oct 24 20:54:08 2025 daemon.info avahi-daemon[5778]: Joining mDNS multicast group on interface tailscale0.IPv4 with address 100.112.22.107.
Fri Oct 24 20:54:08 2025 daemon.info avahi-daemon[5778]: New relevant interface tailscale0.IPv4 for mDNS.
Fri Oct 24 20:54:08 2025 daemon.info avahi-daemon[5778]: Registering new address record for 100.112.22.107 on tailscale0.IPv4.
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 monitor: RTM_NEWROUTE: src=, dst=192.168.5.0/24, gw=, outif=19, table=52
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 wgengine: Reconfig: user dialer
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 tsdial: bart table size: 20
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 wgengine: Reconfig: configuring DNS
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 dns: Set: {DefaultResolvers: Routes:{} SearchDomains: Hosts:14}
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 dns: Resolvercfg: {Routes:{} Hosts:14 LocalDomains:}
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 dns: OScfg: {}
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 peerapi: serving on http://100.112.22.107:48197
Fri Oct 24 20:54:08 2025 kern.debug kernel: [86243.511482] mptcp bind
Fri Oct 24 20:54:08 2025 kern.debug kernel: [86243.511690] mptcp bind
Fri Oct 24 20:54:08 2025 kern.debug kernel: [86243.511734] mptcp accept
Fri Oct 24 20:54:08 2025 kern.debug kernel: [86243.514715] mptcp bind
Fri Oct 24 20:54:08 2025 kern.debug kernel: [86243.519207] mptcp bind
Fri Oct 24 20:54:08 2025 kern.debug kernel: [86243.521724] mptcp bind
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 magicsock: home DERP changing from derp-0 [0ms] to derp-8 [27ms]
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 magicsock: home is now derp-8 (lhr)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 magicsock: endpoints changed: 81.185.166.242:41641 (stun), 10.100.0.2:41641 (local), 192.168.7.1:41641 (local)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 magicsock: adding connection to derp-8 for home-keep-alive
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 magicsock: 1 active derp conns: derp-8=cr0s,wr0s
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 derphttp.Client.Connect: connecting to derp-8 (lhr)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 peerapi: failed to do peerAPI listen, harmless (netstack available) but error was: listen tcp6 [fd7a:115c:a1e0::f836:166b]:0: bind: cannot assign requested address
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 peerapi: serving on http://[fd7a:115c:a1e0::f836:166b]:1
Fri Oct 24 20:54:08 2025 kern.debug kernel: [86243.524235] mptcp bind
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 offline auto-update: stopping update checks
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 Switching ipn state Starting -> Running (WantRunning=true, nm=true)
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 health(warnable=warming-up): ok
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 health(warnable=no-derp-connection): ok
Fri Oct 24 20:54:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:08 control: NetInfo: NetInfo{varies=false hairpin= ipv6=false ipv6os=true udp=true icmpv4=false derp=#8 portmap= link="" firewallmode="ipt-inuse"}
Fri Oct 24 20:54:09 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:09 health(warnable=no-derp-connection): ok
Fri Oct 24 20:54:09 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:09 [RATELIMIT] format("health(warnable=%s): ok")
Fri Oct 24 20:54:09 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:09 magicsock: derp-8 connected; connGen=1
Fri Oct 24 20:54:09 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:09 wgengine: idle peer [gqWvo] now active, reconfiguring WireGuard
Fri Oct 24 20:54:09 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:09 wgengine: Reconfig: configuring userspace WireGuard config (with 3/13 peers)
Fri Oct 24 20:54:09 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:09 magicsock: adding connection to derp-18 for [gqWvo]
Fri Oct 24 20:54:09 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:09 magicsock: 2 active derp conns: derp-8=cr817ms,wr817ms derp-18=cr0s,wr0s
Fri Oct 24 20:54:09 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:09 derphttp.Client.Recv: connecting to derp-18 (par)
Fri Oct 24 20:54:09 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:09 magicsock: derp-18 connected; connGen=1
Fri Oct 24 20:54:14 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:14 wgengine: idle peer [q7I3j] now active, reconfiguring WireGuard
Fri Oct 24 20:54:14 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:14 wgengine: Reconfig: configuring userspace WireGuard config (with 4/13 peers)
Fri Oct 24 20:54:14 2025 daemon.err tailscaled[3246]: 2025/10/24 20:54:14 magicsock: disco: node [q7I3j] d:e053e21989861cee now using 192.168.7.103:39014 mtu=1360 tx=2cd0f49af534
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.170209 [error] dnsproxy: 194.0.5.64:53: response received over udp: "exchanging with 194.0.5.64:53 over udp: read udp 10.100.0.2:57927->194.0.5.64:53: i/o timeout"
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.170316 [error] dnsproxy: upstream 194.0.5.64:53 failed to exchange ;ccp-lh.googleusercontent.com. IN A in 20.002095387s: exchanging with 194.0.5.64:53 over udp: read udp 10.100.0.2:57927->194.0.5.64:53: i/o timeout
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.466296 [error] dnsproxy: 194.0.5.64:53: response received over udp: "exchanging with 194.0.5.64:53 over udp: read udp 10.100.0.2:39731->194.0.5.64:53: i/o timeout"
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.466419 [error] dnsproxy: upstream 194.0.5.64:53 failed to exchange ;connectivitycheck.gstatic.com. IN A in 20.001852324s: exchanging with 194.0.5.64:53 over udp: read udp 10.100.0.2:39731->194.0.5.64:53: i/o timeout
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.470931 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:47269->1.1.1.1:53: i/o timeout"
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.471028 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;connectivitycheck.gstatic.com. IN A in 20.001535781s: exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:47269->1.1.1.1:53: i/o timeout
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.477467 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:44915->1.1.1.1:53: i/o timeout"
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.477573 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;tracker.auctor.tv. IN A in 20.001448373s: exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:44915->1.1.1.1:53: i/o timeout
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.632356 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:57637->1.1.1.1:53: i/o timeout"
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.632459 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;ccp-lh.googleusercontent.com. IN A in 20.001619649s: exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:57637->1.1.1.1:53: i/o timeout
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.647162 [error] dnsproxy: 1.1.1.1:53: response received over udp: "exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:46252->1.1.1.1:53: i/o timeout"
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.647259 [error] dnsproxy: upstream 1.1.1.1:53 failed to exchange ;ccp-lh.googleusercontent.com. IN A in 20.001281023s: exchanging with 1.1.1.1:53 over udp: read udp 10.100.0.2:46252->1.1.1.1:53: i/o timeout
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.677223 [error] dnsproxy: 194.0.5.64:53: response received over udp: "exchanging with 194.0.5.64:53 over udp: read udp 10.100.0.2:55262->194.0.5.64:53: i/o timeout"
Fri Oct 24 20:54:16 2025 user.notice AdGuardHome[12736]: 2025/10/24 20:54:16.677324 [error] dnsproxy: upstream 194.0.5.64:53 failed to exchange ;tracker.auctor.tv. IN A in 20.003201517s: exchanging with 194.0.5.64:53 over udp: read udp 10.100.0.2:55262->194.0.5.64:53: i/o timeout
Fri Oct 24 20:55:03 2025 kern.debug kernel: [86243.526888] mptcp bind
Fri Oct 24 20:55:03 2025 kern.warn kernel: [86298.111179] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Fri Oct 24 20:55:03 2025 kern.notice kernel: [86298.120521] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Fri Oct 24 20:55:03 2025 kern.warn kernel: [86298.127549] 7981@C13L2,MacTableDeleteEntry() 1938: Del Sta:12:1a:ca:01:82:2e
Fri Oct 24 20:55:03 2025 kern.notice kernel: [86298.134824] 7981@C08L3,ap_peer_deauth_action() 437: AUTH - receive DE-AUTH(seq-2917) from 12:1a:ca:01:82:2e, reason=3
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: VERIFY OK: depth=1, O=NordVPN, CN=NordVPN CA10
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: VERIFY KU OK
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: Validating certificate extended key usage
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: VERIFY EKU OK
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: VERIFY X509NAME OK: CN=fr1012.nordvpn.com
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: VERIFY OK: depth=0, CN=fr1012.nordvpn.com
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Fri Oct 24 20:55:42 2025 daemon.notice ovpnclient[4677]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Fri Oct 24 20:56:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:56:08 magicsock: home DERP changing from derp-8 [42ms] to derp-18 [31ms]
Fri Oct 24 20:56:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:56:08 magicsock: home is now derp-18 (par)
Fri Oct 24 20:56:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:56:08 control: NetInfo: NetInfo{varies=false hairpin= ipv6=false ipv6os=true udp=true icmpv4=false derp=#18 portmap= link="" firewallmode="ipt-inuse"}
Fri Oct 24 20:56:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:56:08 magicsock: closing connection to derp-8 (idle), age 2m0s
Fri Oct 24 20:56:08 2025 daemon.err tailscaled[3246]: 2025/10/24 20:56:08 magicsock: 1 active derp conns: derp-18=cr2m0s,wr229ms
Fri Oct 24 20:57:30 2025 daemon.err tailscaled[3246]: 2025/10/24 20:57:30 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:57:36 2025 daemon.err tailscaled[3246]: 2025/10/24 20:57:36 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:57:42 2025 daemon.err tailscaled[3246]: 2025/10/24 20:57:42 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:57:48 2025 daemon.err tailscaled[3246]: 2025/10/24 20:57:48 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:57:54 2025 daemon.err tailscaled[3246]: 2025/10/24 20:57:54 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:00 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:00 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:06 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:06 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:12 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:12 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:18 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:18 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:24 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:24 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:25 2025 daemon.info dnsmasq-dhcp[26912]: DHCPREQUEST(br-lan) 192.168.7.103 bc:df:58:51:85:82
Fri Oct 24 20:58:25 2025 daemon.info dnsmasq-dhcp[26912]: DHCPACK(br-lan) 192.168.7.103 bc:df:58:51:85:82 Chromecast
Fri Oct 24 20:58:29 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:29 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:34 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:34 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:39 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:39 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:44 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:44 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:50 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:50 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:58:55 2025 daemon.err tailscaled[3246]: 2025/10/24 20:58:55 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:59:00 2025 daemon.err tailscaled[3246]: 2025/10/24 20:59:00 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:59:05 2025 daemon.err tailscaled[3246]: 2025/10/24 20:59:05 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:59:10 2025 daemon.err tailscaled[3246]: 2025/10/24 20:59:10 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:59:15 2025 daemon.err tailscaled[3246]: 2025/10/24 20:59:15 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:59:21 2025 daemon.err tailscaled[3246]: 2025/10/24 20:59:21 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:59:26 2025 daemon.err tailscaled[3246]: 2025/10/24 20:59:26 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:59:31 2025 daemon.err tailscaled[3246]: 2025/10/24 20:59:31 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:59:36 2025 daemon.err tailscaled[3246]: 2025/10/24 20:59:36 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 20:59:41 2025 daemon.err tailscaled[3246]: 2025/10/24 20:59:41 magicsock: derp-18 does not know about peer [gqWvo], removing route
Fri Oct 24 21:02:09 2025 daemon.info dnsmasq-dhcp[26912]: DHCPREQUEST(br-lan) 192.168.7.168 94:83:c4:01:93:1b
Fri Oct 24 21:02:09 2025 daemon.info dnsmasq-dhcp[26912]: DHCPACK(br-lan) 192.168.7.168 94:83:c4:01:93:1b GL-MT300N-V2
Fri Oct 24 21:02:30 2025 kern.debug kernel: [86744.492587] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Fri Oct 24 21:02:30 2025 kern.warn kernel: [86744.499663] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:12:1a:ca:01:82:2e
Fri Oct 24 21:02:30 2025 kern.notice kernel: [86744.510978] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 12:1a:ca:01:82:2e
Fri Oct 24 21:02:30 2025 kern.notice kernel: [86744.520479] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Fri Oct 24 21:02:30 2025 kern.notice kernel: [86744.529681] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Fri Oct 24 21:02:30 2025 kern.notice kernel: [86744.535802] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Fri Oct 24 21:02:30 2025 kern.notice kernel: [86744.665566] 7981@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Oct 24 21:02:30 2025 kern.notice kernel: [86744.672262] 7981@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Fri Oct 24 21:02:30 2025 kern.notice kernel: [86744.680207] 7981@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Fri Oct 24 21:02:30 2025 kern.notice kernel: [86744.686882] 7981@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Fri Oct 24 21:02:30 2025 kern.warn kernel: [86744.699299] 7981@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=1 from 12:1a:ca:01:82:2e
Fri Oct 24 21:02:30 2025 daemon.info dnsmasq-dhcp[26912]: DHCPREQUEST(br-lan) 192.168.7.171 12:1a:ca:01:82:2e
Fri Oct 24 21:02:30 2025 daemon.info dnsmasq-dhcp[26912]: DHCPACK(br-lan) 192.168.7.171 12:1a:ca:01:82:2e OPPO-Find-X2-Lite
Fri Oct 24 21:02:30 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:30 magicsock: adding connection to derp-4 for [D0RDB]
Fri Oct 24 21:02:30 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:30 magicsock: 2 active derp conns: derp-4=cr0s,wr0s derp-18=cr8m0s,wr605ms
Fri Oct 24 21:02:30 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:30 derphttp.Client.Recv: connecting to derp-4 (fra)
Fri Oct 24 21:02:30 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:30 magicsock: derp-4 connected; connGen=1
Fri Oct 24 21:02:30 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:30 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:02:34 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:34 magicsock: disco: node [gqWvo] d:f7310ee4e9adf809 now using 192.168.7.0:37572 mtu=1360 tx=c8de6171c5b8
Fri Oct 24 21:02:35 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:35 magicsock: disco: node [gqWvo] d:f7310ee4e9adf809 now using 192.168.7.171:37572 mtu=1360 tx=c32b1f6b0ec2
Fri Oct 24 21:02:35 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:35 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:02:41 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:41 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:02:46 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:46 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:02:51 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:51 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:02:56 2025 daemon.err tailscaled[3246]: 2025/10/24 21:02:56 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:02:57 2025 daemon.err rmmod: unloading the module failed
Fri Oct 24 21:03:01 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:01 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:06 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:06 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:12 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:12 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:17 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:17 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:22 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:22 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:27 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:27 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:32 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:32 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:36 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:36 magicsock: disco: node [gqWvo] d:f7310ee4e9adf809 now using 192.168.7.0:37572 mtu=1360 tx=28dd07e7e79b
Fri Oct 24 21:03:37 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:37 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:42 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:42 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:43 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:43 magicsock: disco: node [gqWvo] d:f7310ee4e9adf809 now using 192.168.7.171:37572 mtu=1360 tx=b5b7f963b8bf
Fri Oct 24 21:03:48 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:48 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:53 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:53 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:03:58 2025 daemon.err tailscaled[3246]: 2025/10/24 21:03:58 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:04:03 2025 daemon.err tailscaled[3246]: 2025/10/24 21:04:03 magicsock: derp-4 does not know about peer [D0RDB], removing route
Fri Oct 24 21:04:08 2025 daemon.err tailscaled[3246]: 2025/10/24 21:04:08 magicsock: derp-4 does not know about peer [D0RDB], removing route
The router switches between 4G and 5G networks at t fixed time periods, this may be related to the operator's behavior or network-side configurations.
Router cannot reconnect to network when cellular connection drops, this might be related to config or modem. Do you use the APN provided by the sim card provider? Could you provide the log that records the entire process from network disconnection to reconnection?
Hello, Thanks for your last feedback . The previous issue was RAM overloaded with adguard home and disabling modem multiwan tracking.
I would like to use last 4.8.3 firmware (multiVPN instance is great and multicard switching working far better).
I recently tried firmware 4.8.3 for glx3000, but i reverted it to 4.7.4 because of 5G random instability .
Im still having the Modem version : RM520NGLAAR03A03M4G (untouched / unflashed so far too scared ). My mobile French operator : SFR/reglomobile (mvno) 5G NSA.
I have heard that to solve 5G stability issue with router firmware 4.8.3, I have to update the modem firmware from RM520NGLAAR03A03M4G to RM520NGLAAR03A04M4G ( in date of 2024-3-28).
Should I really flash the modem firmware (Im scared to kill the modem)?
Is it better to do it from the admin panel or via cli ?
Do you know where I can find that official image ?
Thanks for yours replies
