I run a lot of local services on an Ethernet connected machine. Such as plex media server or homeassistant. These services don’t seem to work between ethernet and wifi. They appear to be dropped by the firewall. I’ve verified both are in the “lan” bridge. Other ports, that are also opened to the router, such as 22 seem to work fine. I can’t for the life of me see why these ports are being filtered. I’m not sure if anyone can help. I’m resistant to resetting because of the trouble to get the cellular configured correctly again. So I thought I’d ask here for for ideas of what might be wrong.
Hello
Could you please clarify further:
- The devices unable to access the local LAN server – are they connected via wired Ethernet or Wi-Fi, or both?
- If connected via Wi-Fi, please ensure they are connected to the main Wi-Fi network rather than the Guest network
- Is pinging the local LAN server successful on issued devices?
