Hi everyone
My device now shows offline after I moved from Wireguard client vpn to OpenVPN Client on my GL-AR300M.
I set up a wireguard server on Azure to test it and everything worked fine, I was able to see my device online in the dashboard in Goodcloud, but after I switched to OpenVPN hosted by PureVPN my device no longer shows online and need some help getting it back online.
In PureVPN I added the option to port forward, they only have 3 options
Open all ports
Block all ports
Block all ports but enable following:
I selected the last option since I need to port forward some ports but I believe there is a port or ports used by Goodcloud that were closed because of it, does anyone have a list of listening ports used between my GL-AR300M to Goodcloud that can share with me?
If anyone can share of point me to the right direction I greatly appreciate it.
Thank you
