it seems goodcloud includes recently (tested with firmware 3.201) a connection to the web gui and a web bases ssh connection to the router, working even when the router is in a NAT.
Is that new functionality going to be there from now on?
Yes, you should enable this in the cloud section in your firmware first.
I know this is an old thread, but it’s the only relevant one I could find.
Where in the Web UI are the options to connect via SSH/Web, as I can’t see them, even though I’ve activated the options on the device.
Cheers.
Thanks, now I see those.
I think the issue is that I was already logged into goodcloud before I enabled the access.
Cheers.
