My mango will not reset. I have tried holding reset for 10 seconds and releasing. I have also tried holding for 3 seconds.
It is plugged into power outlet and showing power light on. Other lights are off.
Using my Android phone, I am not seeing the default ssid (GL-xxxxxx-xx) or the ssid I created using the web interface.
The router was set up as a bridge and worked for a short time, but the wifi network I created using the mt300n is no longer available, which is why I am trying to reset.
