Hi all,
any chance to create a Guest SSID that does not see the lan but only se internet connection?
regards
/Silvano
Hi all,
regards
/Silvano
There is a “recipe” on OpenWrt for this: Configure a guest WLAN using the Luci web-interface [Old OpenWrt Wiki]
I just configured it and had 2 issues.
My interface is light green not purple, which I assume means something, but do not know what.
I also could connect to the device, but could not connect to the internet, until for the last rule (Guest DHCP) I added the restriction to the source for ports 67-68 (as opposed to any). This is included in the CLI config, but not the GUI config. ([OpenWrt Wiki] Guest Wi-Fi basics)
I do not have a way to test the LAN security between the networks.
The Interface color is determined by the zone it is attached too, and the zone color is determined by a random related to the name.
https://forum.openwrt.org/viewtopic.php?pid=340341#p340341
The green is not an issue.
