Guest WiFi Access Restriction Configuration Issue - GL-X3000
I have a problem setting up the Guest WiFi network. I would like to configure it so that all users are disconnected from the guest WiFi after one hour, and the next connection to the network is only possible after another hour.
Here are my router details:
Model: GL.iNet GL-X3000
Firmware Version: OpenWrt 21.02-SNAPSHOT r15812+882-46b6ee7ffc / LuCI openwrt-21.02 branch git-22.245.77575-63bfee6
Kernel Version: 5.4.211
Best regards
Currently, there are no related functions on WiFi.
Please consider using Parental Control, which can control when some clients allow access to the Internet.
This is a network provided in the store, and I need a solution that will allow me to fully manage the Wifi Guest network. Is there any additional plugin that provides such functionality?
It seems that there are no plugins that can meet this requirements.
You can discuss on the OpenWRT forum to try to find.
