I want to install Home Assistant on a GL-iNet S1300 router following the instructions from GitHub - gl-inet/home-assistant-on-openwrt. Since all attempts on the current firmware 3.203 failed, I installed the older version 3.023 (used in the instructions) via UBoot and thus I was able to install Home Assistant apparently without any problems.
But when starting HA with hass -c /data/.homeassistant the execution was blocked
The screenshot after interruption of executation will come in the next post because i can insert just one file in a post.
After a new attempt, as suggested in the instructions, the execution is blocking on the same step.
I am grateful to everyone who can help me to install Home Assistant on my router
