Hardware Acceleration turned off in LuCi?
I’ve noticed with the latest GL-MT6000 firmware that hardware acceleration is enabled by default but when you go to the LuCi page under firewall settings it’s turned off?
I believe the previous firmware didn’t have this issue, Is this a bug or something that needs to be looked in two?
I’ve tried enabling it but it doesn’t stick and it reverts to being off again
The closed-source or open-source firmware?
Hardware acceleration is only controlled in the GL GUI.
Luci will not synchronize this parameter (0 or 1).
I think it does not consider repair for the time being.
Since this parameter from Luci may be different with the GL GUI.
