Understood and thank you alzhao! IE: 2nd of February to 15th of February, 2017 eh?
Yes; here entertaining just connecting 5VDC to the labeled 5VDC point that I am using for the RTC device or soldering a wire to the other side of the fuse for a temporary solution.
That said also noticed a combo 6416A with POE and antenna on Amazon.
Looking at the two ICs there doesn’t seem to be any damage to them…that said it is hard to tell. Historically with other devices I have seen first in line fuses / diodes go out.
I have not tested these fuses / diodes yet until I remove the board from the case.
Removed board from case and using a VOM to check for open diodes or shorts if possible.
