Having a problem running a script from the terminal
First, I set the file as executable, and then execute it.
root@GL-E750:/# chmod +x ./airplane_mode.sh
root@GL-E750:/# ./airplane_mode.sh
Then I receive an error message:
-ash: ./airplane_mode.sh: not found
The contents of the bash script are as follows:
#!/bin/bash
SSID=$1
if [ iw dev wlan0 scan | grep "$SSID" ];
then
echo "Internet nearby"
else
echo "Internet not nearby"
fi
What could be causing my issue?
Thank you.
Change #!/bin/bash to #!/bin/sh
I did this, now I'm getting a completely different error message:
sh: missing ]
grep: ]: No such file or directory
Internet not nearby
Do I have a syntax error?
