Just today the micro USB connector came off from the GL-MiFi board.
Can I power (5 volts) the boar by using the two solder pads (+/-) from J6 (located next to the power button)?
Version 1.
Hi There is a Capacitance below the Micro USB connectot named C24, you can connect your 5V power on it.The pin closed to the edge of board is GND,the other pin is 5V.PLEASE SEE THE ATTCAHMENT
Got it… Will test and report back!
Thank you!
