Help-not wanting Linux file system drive to show
I have work computer that comets works great on but in Device manager, it showing "Linux file system drive"
I don't use file sharing, I don't want to mount anything just strictly use it for remote management. (Keyboard,mouse,video)
Anyway I can kill storage mount when I plug in USB-C connection
Any help would be greatly appreciated
Thank you!!!! I might need to install the firmware update. I'm on 1.0 and that option is not present. It's only format..
Thank you
